FON firmware on the Netgear?
7 posts / 0 new
skynetbbs
skynetbbs's picture
The FONbasic source code for the Linksys router, based on OpenWrt is available to download at http://download.fon.com/firmware/0.6.6/FONbasic-0.6.6.tar.bz2
The FONbasic source code for La Fonera, based on OpenWrt is available to download at http://download.fon.com/firmware/fonera/latest/fonera.tar.bz2
The FONbasic source code for La Fonera+, based on OpenWrt is available to download at: http://download.fon.com/firmware/foneraplus/latest/foneraplus.tar.bz2
someone able to create a NetGear version out of one of these?
skynetbbs
skynetbbs's picture
Cable provider ZON in
Cable provider ZON in Portugal is installing NETGEAR routers with FON firmware built in....so Netgear allready ported FON functionality
Nachi
Nachi's picture
Souvik is working on a
Souvik is working on a Netgear OpenWRT port. Once that's working, we hopefully would be able to get it through the openwrt.org and after that it will be much easier to use FON on the open source router.
skynetbbs
skynetbbs's picture
Hi, if the netgear CPE (used
Hi, if the netgear CPE (used by ISP ZON in Portugal) is allready "fon"compliant; why can't it be made available for all other netgear firmware out there?
Nachi
Nachi's picture
Any idea about what chipset
Any idea about what chipset/flash/sdram the CPE with FON uses? and what is the firmware version? If it is the same one as WGR614L -- well and good. We may be able to use the code.
If it is not the same router as WGR614L then we need to port that code to Netgear firmwares for WGR614L or its other open source variants. Which can be done using any of the FON opensource version and is completely independent of whether other Netgear routers runs FON or not.
Also A netgear router running an application doesn't really mean Netgear has the access to its source code or has the right to release it. It may or may not depending on how the CPE was implemented, who was the software vendors etc.
I will try to find out more details about this. If anything interesting comes up will post an update here.
foryoulove
foryoulove's picture
Thank you for the post, after that I read a lot.
MCSE
ccna
skynetbbs
skynetbbs's picture
MCSE
ccna
you can do a svn co https://svn.fonosfera.org/fon-ng fon
and do a make menuconfig
and select broadcom (???)
make world
and try to create these strange TRX/CHK images?
