Guest Access/Hotspot
2 posts / 0 new
m698322h
m698322h's picture
Hi, we have a business and we also live upstairs from the business and want to open up internet for our customers at the same time of protecting our home and business systems (wired/wireless) from the public.
I saw there is an independant release that allows you to configure a guest SSID (http://www.myopenrouter.com/article/10373/Configuring-Guest-SSID-using-My-OpenRouter-Independent-Firmware-Build/?highlight=guest+access) and this is something that would be perfect to protect public from accessing our systems without having to hookup two non open source routers to the ISP router.
 Does DD-WRT or tomato allow one to configure something like this also, as I want to use the least amount of hardware but have better control.
 Also how does the inbound firewall compare to the manufactures build (compare independent, dd-wrt, and tomato)
SouvikGhosh
SouvikGhosh's picture
No tomato. dd-wrt does not
No tomato. dd-wrt does not support this guest ssid feature. You should use the independent firmware build for this feature.
Besides this tomato, dd-wrt still have some issues with the wireless module. So, better to use the MOR independent build.
