Help! Problems upgrading dd-wrt on router
4 posts / 0 new
damani
Ok i tried to update my router to the newest dd-wrt. I am stuck at a certain point though. I went through all the steps(i do not have a serial cord) using erase_mtd way of doing it. Now i am at the point where i must tftp the dd-wrt to the router, but i keep getting the cannot find host error. I have setup the ip on my computer to
ip:192.168.1.1xx
subnet mask: 255.255.255.0
gateway: 192.168.1.1
Preferred DNS: 192.168.1.1
I have tried this multiple times, but yet i am still unable to ping my router. I have the router plugged in the lan port 1. I have tried using other ports too.  I also have 2 lan ports on my computer. I have tried using both of them switching back and forth but no luck. Do i have have something setup wrong?  When i have the router plugged in the power light is blinking so im assuming its in tftp mode.  I dont know what i am doing wrong.  I have tried to ping the router also, but get no response.  Thanks for any help
mona
reboot the router again and
reboot the router again and wait for booting it up. Then i think you will get the ping.
damani
i have rebooted it quite a
i have rebooted it quite a few times and waited for ping.
damani
i try and ping it for 5
i try and ping it for 5 minutes with no luck. i dont know what the problem is
