Hello people.
I am trying to create one file into the jffs2 partition without success. Follow the error:
root@(noname):/# mount /dev/mtdblock/4 /jffs -t jffs2
root@(noname):/# cd /jffs
root@(noname):/jffs# ls
root@(noname):/jffs# mkdir k
Write of 68 bytes at 0x00002d90 failed. returned 0, retlen 136
mkdir: Cannot create directory `k': Input/output error
root@(noname):/jffs# df -h
Filesystem Size Used Available Use% Mounted on
/dev/root 2.6M 2.6M 0 100% /
tmpfs 7.0M 20.0k 7.0M 0% /tmp
/dev/mtdblock/4 448.0k 324.0k 124.0k 72% /jffs
Note that the partition is empty and it is showing 72% used.
Somebody know what is happening? and what can I do?
Thanks for any help.
Seems that jffs has problems with serial flash. And if you could write something to jffs, router will not boot on next boot, because checksum (done by cfe) will fail. (At least with cfe 1.5)
I don't know if there will be a solution to this soon. If you find it, please let me know.
Eko
Please check the post at
http://www.myopenrouter.com/forum/thread/10590/Booting-OpenWRT-From-the-...
for a fix in the sflash_mtd_write() in OpenWRT.
The same fix also works on dd-wrt.
In dd-wrt you may enable to the JFFS2 without hitting the checksum issue. Checksum is computed only over the trx length and JFFS2 lies outside the trx boundary.
Nachi
Nachi, thanks a lot for the hint.
Have you some tips to fix the empty data partition that has incorrect free space as follow:
/dev/root --------------- 2.6M ---- 2.6M --- 0 --- 100% /
tmpfs ------------------- 7.0M --- 20.0k --- 7.0M -- 0% /tmp
/dev/mtdblock/4 --------- 448.0k - 324.0k -- 124.0k -72% /jffs
Thanks again.
trying to figure what is eating up the 324k. The same memeory is also eaten up in OpenWRT - but since the partition size is much higher (1.7M) so this is only showing about 20%.
