WGR614 + insmod wl.o error
5 posts / 0 new
Fmay
Fmay's picture
 I'm trying to insmod wl.o without success, I'm not sure what happened with this because it was Ok.
root@(none):/jffs# insmod wl.o
Using /lib/modules/2.4.35.4/wl.o
Warning: loading wl will taint the kernel: non-GPL license - Proprietary
  See http://www.tux.org/lkml/#export-tainted for information about tainted modules
PCI/DMA
wl0: wlc_attach: failed with err 16
wl%d: 4.150.10.5 driver failed with code 16
Memory leak of bytes 10724
insmod: init_module: wl: No such device
Thanks for any hint to correct it.
Nachi
Nachi's picture
Also do send the nvram
Also do send the nvram settings
particularly sromrev
it should be set to 3.
Fmay
Fmay's picture
Das,
Das,
I'm using an hybrid kernel. It is an OpenWrt patched kernel with some parts of DD-WRT and some modifications.
I fix this problem as Nachi say:
root@(none):/# nvram show | grep sromrev
sromrev=2
size: 9452 bytes (23316 left)
root@(none):/# nvram set sromrev=3
root@(none):/# nvram commit
root@(none):/# insmod wl
PCI/DMA
wl0: wlc_attach: chiprev 3 coreunit 0 corerev 13 cccap 0x104001ea maccap 0x30482205 band 2.4G, phy_type 5 phy_rev 0 ana_rev 6
wl0: Broadcom BCM4318 802.11 Wireless Controller 4.150.10.5
root@(none):/# insmod wlcompat
Using /lib/modules/2.4.35.4/wlcompat.o
Thanks again.
Fmay
Fmay's picture
It error always happens after
It error always happens after pressing reset button. (WGR614v8 NA)
Nachi
Nachi's picture
Yes, this error will happen
Yes, this error will happen if you press the factory reset. One way to handle this is to force the preinit script to do the sromrev checking and then do a reboot after correcting that if it was wrong.
Other part is to correct it at the time of nvram initialization in the Kernel.
Nachi
