I was updating the firmware and after it finished the green checkmark started flashing. I cannot connect to my router now to check the firmware or do anything, Any ideas??
2.023 10 23 is the version. I know know is not the most up to date but I was having problems with disconnects and this firmware had the "solution" to them. Anyway, it did not like it because the green check light now flashes on and off. The green power light is solid and the " i " for internet is also solid amber color. The 1, 2, 3, 4 numbers are also solid if I connect any of my computers to them. What I dont have is the antenna symbol wich is the wireless symbol working in addition to the checkmark flashing. How can I use the "factory default by hardware"? I keep clicking on the back of the router on the reset button and it resets but then it starts flashing again.
Ahh, by the way. I tried clicking and holding the reset button on the back for 15 seconds and it still blinks after reseting.
do you have serial cable? if yes, please send the log message.
