Compiling DD-WRT with OpenVPN feature
14 posts / 0 new
achilles
achilles's picture
Hi all,
I am trying to compile DD-WRT with openvpn feature .
The steps I took for the same are as follows :
1. copy .config_openvpn.v24 to .config under router directory .
2.make clean;make
But make fails and I am getting some strange error messages such as :
/home/dd-wrt/toolchains/4.1.0-uclibc-0.9.28/bin/../lib/gcc/mipsel-linux-uclibc/4.1.0/../../../../mipsel-linux-uclibc/bin/ld: BFD 2.16.1 assertion fail /home/openwrt/trunk/openwrt/toolchain_build_mipsel/binutils-2.16.1/bfd/elfxx-mips.c:2562
/home/dd-wrt/toolchains/4.1.0-uclibc-0.9.28/bin/../lib/gcc/mipsel-linux-uclibc/4.1.0/../../../../mipsel-linux-uclibc/bin/ld: BFD 2.16.1 assertion fail /home/openwrt/trunk/openwrt/toolchain_build_mipsel/binutils-2.16.1/bfd/elfxx-mips.c:2346
/home/dd-wrt/toolchains/4.1.0-uclibc-0.9.28/bin/../lib/gcc/mipsel-linux-uclibc/4.1.0/../../../../mipsel-linux-uclibc/bin/ld: BFD 2.16.1 assertion fail /home/openwrt/trunk/openwrt/toolchain_build_mipsel/binutils-2.16.1/bfd/elfxx-mips.c:2350
nflow.o: In function `process_netflow_cache':
nflow.c:(.text.process_netflow_cache+0x6bc): relocation truncated to fit: R_MIPS_CALL16 against `free'
servers.o: In function `end_servers_r':
servers.c:(.text.end_servers_r+0xf4): relocation truncated to fit: R_MIPS_CALL16 against `free'
servers.o: In function `add_server':
servers.c:(.text.add_server+0x90): relocation truncated to fit: R_MIPS_CALL16 against `free'
storage.o: In function `flow_update':
storage.c:(.text.flow_update+0x3a4): relocation truncated to fit: R_MIPS_CALL16 against `free'
disp.o: In function `display':
disp.c:(.text.display+0x1bc): relocation truncated to fit: R_MIPS_CALL16 against `free'
psrc.o: In function `destroy_packet_source':
psrc.c:(.text.destroy_packet_source+0x2c): relocation truncated to fit: R_MIPS_CALL16 against `free'
psrc.c:(.text.destroy_packet_source+0x64): relocation truncated to fit: R_MIPS_CALL16 against `free'
psrc.c:(.text.destroy_packet_source+0x90): relocation truncated to fit: R_MIPS_CALL16 against `free'
psrc.o: In function `create_packet_source':
psrc.c:(.text.create_packet_source+0xe8): relocation truncated to fit: R_MIPS_CALL16 against `free'
/home/dd-wrt/toolchains/4.1.0-uclibc-0.9.28/bin/../lib/gcc/mipsel-linux-uclibc/4.1.0/../../../../mipsel-linux-uclibc/bin/ld: BFD 2.16.1 assertion fail /home/openwrt/trunk/openwrt/toolchain_build_mipsel/binutils-2.16.1/bfd/elf-strtab.c:241
collect2: ld returned 1 exit status
make[1]: *** [rflow] Error 1
make[1]: Leaving directory `/root/Netgear_work/DD-WRT/src/router/rflow'
make: *** [rflow] Error 2
 Could any body plz tell me why this happens ... It seems there is some problem in compiling rflow directory ....
I have successfully compiled DD-WRT for mini build (where rflow was absent ) and now need to compile it for OpenVPN ... could anybody plz tell me how to overcome this ..
Goddchen
Goddchen's picture
Hi achilles :)
Hi achilles :)
I'm currently trying the same (openvpn build)...
but i'm stuck at some other errors (and already fixed some more errors, but not the one that you are facing :( )
/home/goddchen/dd-wrt/toolchains/4.1.0-uclibc-0.9.28/bin/../lib/gcc/mipsel-linux-uclibc/4.1.0/../../../../mipsel-linux-uclibc/bin/ld: BFD 2.16.1 assertion fail /home/openwrt/trunk/openwrt/toolchain_build_mipsel/binutils-2.16.1/bfd/elf-strtab.c:241
There are about 20 of those errors... I'm working on it...
A hint: I did "make configure" after copying the new .config file... Perhaps this helps you too?
Goddchen
Goddchen's picture
I found a hint that one needs
I found a hint that one needs to compile that rflow thing first with gcc 3.x and then compile the rest with gcc 4.x. I tried it but all i get is:
~/dd-wrt/dd-wrt_scripts/DD-WRT/src/router/rflow$ make
cc -DIPCAD_VERSION=\"3.6.2\" -DCONFIG_FILE=\"/tmp/etc/ipcad.conf\" -DHAVE_CONFIG_H -D_REENTRANT -D_THREAD_SAFE -DIFST_linux -I -DHAVE_CONFIG_H -W -Wall -ffunction-sections -fdata-sections -Wl,--gc-sections -o main.o -c main.c
main.c:12: error: expected declaration specifiers or â...â before âsetpriorityâ
main.c:12: error: expected declaration specifiers or â...â before âwhichâ
main.c:12: error: expected declaration specifiers or â...â before âwhoâ
main.c:12: error: expected declaration specifiers or â...â before âprioâ
main.c:12: warning: data definition has no type or storage class
main.c:12: warning: type defaults to âintâ in declaration of â_syscall3â
make: *** [main.o] Error 1
achilles
achilles's picture
yep ... I also tried this but
yep ... I also tried this but now I am getting stuck in SNMP directory as their is no Makefile and running ./configure fails ....
I m doing some googling and trying ... lets see if we can fix this ... what I have done upto now is as follows :
1. cd DD-WRT/src/router
2. cp .config_openvpn.v24 .config
3. cp ../linux/linux/.config_std ../linux/linux/.config and
make clean
4. export PATH=/opt/3.4.6/bin:$PATH
5. make rflow
6. export PATH=/opt/4.1.0/bin:$PATH
7. make
U too can try these steps to see if u get any further ..
Goddchen
Goddchen's picture
I experienced the same problem yesterday. I think i solved it by running ./configure too. Why does it fail for you? Can't ./configure be executed or does the configure process fail at some point?
achilles
achilles's picture
the configure process is failing for me with error :
checking for a sed that does not truncate output... mkdir: cannot create directory `/root/tmp/sed7743-8183': No such file or directory
: cannot create a temporary directory in /root/tmp
Any ideas .....
Goddchen
Goddchen's picture
not only an idea, i have the
not only an idea, i have the solution :D
just create that directory... it was complaining about not finding /home/goddchen/tmp/ on my machine, i just did
mkdir /home/goddchen/tmp/
and everything went just fine
Goddchen
Goddchen's picture
hm, strange...
hm, strange...
i'm now getting
/home/goddchen/dd-wrt/toolchains/4.1.0-uclibc-0.9.28/bin/../lib/gcc/mipsel-linux-uclibc/4.1.0/../../../../mipsel-linux-uclibc/bin/ld: BFD 2.16.1 assertion fail /home/openwrt/trunk/openwrt/toolchain_build_mipsel/binutils-2.16.1/bfd/elfxx-mips.c:2562
make[3]: Leaving directory `/home/goddchen/dd-wrt/dd-wrt_scripts/DD-WRT/src/router/lzo/minilzo'
make[3]: Entering directory `/home/goddchen/dd-wrt/dd-wrt_scripts/DD-WRT/src/router/lzo'
so i did the trick with compiling it seperately beforehand with gcc 3.x which worked just fine. Next i went back to src/router directory and did "make" again. The problem is, that "make" removes the compiled stuff and compiles it again with gcc 4.x which of course fails again.
Any idea how i can prevent "make" from removing the compiled files?
achilles
achilles's picture
thnx a lot man ... I am
thnx a lot man ... I am through with the compilation process ... Now I need to create a set up to test OpenVPN feature on DD-WRT on WGR614L ..
I will let u know once I m done with this ... :)
Goddchen
Goddchen's picture
hey, great that I could help
hey, great that I could help YOU this time :)
forget about my last posting, i get this error when i compile with gcc 3.x seperately, too :( I've just overseen it. :( Any idea regarding that error?
Goddchen
Goddchen's picture
hm, what exactly did you do
hm, what exactly did you do to fix that assertion error?
achilles
achilles's picture
Goddchen said:
I created tmp directory in /root .
But I am not getting this lzo error ... One thing I observed is that in for openvpn related packages some package specific makefiles are missing so it would be better to run a make configure before issuing a make command  ...
Plz try this and let me know the result ...
Goddchen
Goddchen's picture
damn, i'm still stuck at that
damn, i'm still stuck at that assertion error
it's not something with that tmp directory, i created it.
what else did you do to fix that?
achilles
achilles's picture
OK ... I did nothing specific
OK ... I did nothing specific for this .... I dnt rmmbr if I even got this error or not ...
BTW one more change I would suggest :
In Makefile under linux.v24_2 there is a variable named SUBLEVEL = 37 make it 36..
I dnt know if this is related 2 ur error or not but u can try with it and et me know ..
