Installing the other variants (standard, VPN) of DD-WRT on the WGR614L
3 posts / 0 new
whosane
whosane's picture
I've been wanting to install DD-WRT(svn11793) on my WGR614L and was doing a lot of reading to make sure i don't do it wrong. The DD-WRT wiki as well as the installation guide here mentions that i need to first flash the router using the .chk variant of DD-WRT. However, the .chk variant is only the mini version of DD-WRT. If i then want to flash the standard version of dd-wrt which is a .bin file, i could simply use the mini versions upgrade page to do so.
The dd-wrt installation wiki says the following :
If the
firmware you are loading is before svn11600 then you will need to
update the firmware using this file first before upgrading to a newer
build. After the initial .chk flash (after svn11600) any generic .bin
file can be used to upgrade firmware to the router using the dd-wrt
Firmware update tab.
So, i thought all was ok untill i came across a few threads which said that if i tried to flash the .bin version it would brick my router.
So, what is the right thing to do. Should i just install the mini version which is a .chk file and stop or can i then go ahead and install any of the other supported builds which are in .bin format after first flashing with the .chk version.
This is my first time in flashing a router and so i am in a dilemma as to what to do. Would appreciate any help.
achilles
achilles's picture
If the firmware you are loading is before svn11600 then you will need to update the firmware using this file first before upgrading to a newer build. After the initial .chk flash (after svn11600) any generic .bin file can be used to upgrade firmware to the router using the dd-wrt Firmware update tab.
After flashing a .chk mini build ...u can go to GUI interface for f/w upgrade and flash a .bin file ....
remember 2 do hard factory reset after every flash .....
whosane
whosane's picture
achilles said:After flashing
achilles said:After flashing a .chk mini build ...u can go to GUI interface for f/w upgrade and flash a .bin file ....
Thanks Achilles,
I'll be trying it out this weekend and will post the results here if all goes through fine.
