Tathagata Das just uploaded a brand new version of the Tomato firmware for WGR614L, built upon the most recent Tomato version and source code:
http://www.myopenrouter.com/download/10948/Tomato-Firmware-for-NETGEAR-W...
Please post your comments and experiences with this firmware!
I tried this - the linked file, http://www.myopenrouter.com/download/10948/Tomato-Firmware-for-NETGEAR-W... downloads a file named Tomato_Firmware.gz.zip.
unzipping that yielded a file named Tomato_Firmware. Gunzipping that yielded a file named Tomato_Firmware, which appears to be the Readme file.
Perhaps you linked to the wrong file? Or I did something wrong?
Please advise; I'm happy to test.
Orv
I downloaded the tomato f/w from the link mentioned in your post .... After gunzipping we get a directory named
Tomato_Firmware and this directory contains a README file and a f/w file named tomato_wgr614l.chk ...
Please look properly into the Tomato_Firmware directory that u r getting ....
Do let me know if u still face any pblm ...
Hi guys, any idea why the router is giving me
I get the same results as you - a file named Tomato_Firmware with no extension. However, this file is 2,890 KB in size, which looks about right for a firmware image. Should this file be renamed to add the .chk extension? I'm wary of trying this and potentially bricking the router.
Ray,
Extract TomatoFirmware.gz.zip so you get TomatoFirmware.gz
Rename TomatoFirmware.gz to TomatoFirmware.tar.gz
WinRAR and most other archive tools are too dumb to detect a file type properly.
OK ... I dnt know y u r getting this problem ... I did the following things to get it :
unzip Tomato_Firmware.gz.zip
tar -zxvf Tomato_Firmware.gz
These two steps give me the directory Tomato_Firmware which contains the files
README & tomato_wgr614l.chk
Please check using these steps ....
I downloaded from the link again. I got a file named
I unzipped it and got a directory
__MACOSX/
which contains a file
._Tomato_Firmware.gz
which is a Mac AppleDouble encoded Macintosh file
HOWEVER:
The .gz file also contained a file entitled
Tomato_Firmware
It turns OUT, upon inspecting the file with the file command, that it's actually a GNU tar file.
By doing tar xvf Tomato_Firmware
I got the follow files in a directory called Tomato_Firmware:
Tomato_Firmware/README
Tomato_Firmware/tomato_wgr614l.chk
So - the tar file isn't named tar... that's pretty confusing.
Orv
OK, I successfully untarred the latest version. It has a size of 2949178 bytes and an md5sum of e7b12da14f6b87f2f6c6cc54522195d1. That's different than the released version.
I uploaded it to the router, which reset as expected.
But I wound up still running the old version:
Tomato Firmware v1.11.41510
Copyright (C) 2006-2007 Jonathan Zarate
http://www.polarcloud.com/tomato/
Built on Tue, 15 Apr 2008 23:20:30 -0700
It's like the router rejected the upload. Wonder what's wrong?
Hi, the problem that I was going to ask about was the unzipping/untarring that turned out to be the windows rar program...
So, I successfully installed it, and the only issue I got is the wireless site survey - once I press the refresh button the router "hangs" in a way - it starts to lose packets on the local ethernet side and the web GUI is not accessible
Any ideas?
Just to add that the router stays in that "hanged" situation until being reset by switching off the power
Hi Tathagata, any clues on my problem?
Not that this is so critical for me, but it would be nice to see the usage of the 2.4GHz spectrum upon installing the router
I think you must be referring to Tomato/MLPPP, which is a fork of the official Tomato firmware. Here is a link to the "About" page that describes this fork:
http://fixppp.org/index.php?p=about
It looks like the latest stable build of this version is 1.19. Build 1.21 looks to be an alpha version
I'm afraid I don't personally have the tools and know-how to create a build of the Tomato/MLPPP version from its source code. Maybe someone on this forum can help, or you could appeal to the authors. I didn't see any direct contact information at their "official home" (www.fixppp.org) but they are known to hang out in the DSL Reports forums. Try the following url.
http://www.dslreports.com/forum/teksavvy
Good luck!
Downloaded and installed the firmware. Same version that has the mac osx dir and the non-.tar tarball. Immediately on reconnect many of the web-interface things were displaying outside of their fields and causing issues. I reset it and they went to where they were suppose to be. Unfortunately, I need to use this system for work in a couple hours and the wireless kept dropping. I may play more this weekend.
Tathagata, Anyone...
did someone tested the "wireless site survey". It hangs my router!
Everything else is working just fine so far, but the site survey issue is a little worrying, because I'd like to have the option to see the 2.4GHz spectrum and choose the right channel
hi,
which type of file u r using for f/w upgrade .... is it .chk , .bin or .trx ...
let me know ... I think it expects a .chk file and if we give a file of some other type then this sort of pblms happen ....
Let me know abt ur proceedings in this regard ..
OK let me check it at my side and see how can we solve this ... I will let u know abt this once I get any brkthrough ...
After reading this thread about the file renaming about the tarball, it sounds like this was an effort get the firmware out there for use & testing ASAP - which is fine.
However, over on the download page for the latest Tomato version, there's no indication the source code is bundled with it. I added that observation.
http://www.myopenrouter.com/download/discussion/11030/Where-the-source-c...
Please provide the original and modified build source used per the Tomato source license so others make review, modify and build their own.
Thanks, Mark S.
проститутки Ивановское
вызвать проститутку барнаул
проститутки м Арбатская площадь
тюменские проститутки
ляди проститутки путаны
проститутки Саров
проститутки прайс симферополь
проститутка массаж с мануальной терапией
проститутки конаково
дешевые ярославские праститутки
фото иркутских проституток
проститутки новогиреево новокосино
фото аналов проституток
проститутки выхина
онлайн работа шлюх
элитные проститутки пензы
ефрейтора дочь проститутку
проститутки метро сходненская планерная
