Working router now no longer works....
18 posts / 0 new
AChernow
AChernow's picture
I had a dd-wrt installed and running on my WGR614.  It was working up until I had to unplug the router to move it.  When I plugged everything back in, nothing.  I can't ping the router and it's acting as if it's completely dead.
I know everything is working with the computer and internet connection, because I threw a different router in the line and it works just fine.
 -Adam
rakha
rakha's picture
Its strange. Is the power LED
Its strange. Is the power LED on?
I think there is some problem with your new setup. Please check the power supply. Or you can check your WGR614 in the previous setup. If it is still working there, then you can conclude that problem is in your new setup.
AChernow
AChernow's picture
Yes... and it was showing a link light.  Honestly, all I did was change where the router was plugged in.  I was consolidating 2 powerstrips into one because I no longer had a need for the 2nd one.  So the only thing that changed was WHERE the power supply was plugged in at.  They router was never physically moved.
 -Adam
rakha
rakha's picture
Please tell me the problem in
Please tell me the problem in detail like :
1. what is link light?
2. is the power LED blinking or glowing?
3. If you connect ethernet cable, is corresponding LED glowing?
I dont know exactly what you have done with the power supply. But wrong power input may damage the router.
AChernow
AChernow's picture
Ok.  I plugged the router
Ok.  I plugged the router back in to show you what is happening.
The power light is steady.  If I plug in an ethernet cable it'll light up that light, but I can't even get to 192.168.1.1 to log into the router's control panel, or for that matter, get a DHCP IP from the router.
 This is what is lit up:
(Internet not currently plugged into the router)
As for power adapters, I'm using the same one that came with the unit.  Same one as I always have been using.  The only change I made (at the time) was unplugging the router from one power strip and plugging it into another.  Honestly, that should not have been enough to brick a *working* dd-wrt install.
-Adam
 Edit: Ping attempt with console:
Last login: Tue Jan 13 20:18:27 on ttyp1
Welcome to Darwin!
You have new mail.
[cordelia:~] adam% ping 192.168.1.1
PING 192.168.1.1 (192.168.1.1): 56 data bytes
64 bytes from 192.168.1.1: icmp_seq=26 ttl=100 time=1.123 ms
^C
--- 192.168.1.1 ping statistics ---
211 packets transmitted, 1 packets received, 99% packet loss
round-trip min/avg/max/stddev = 1.123/1.123/1.123/nan ms
[cordelia:~] adam%
..and the output of Firefox:
Network Timeout
The server at 192.168.1.1 is taking too long to respond.
The requested site did not respond to a connection request and the browser has stopped waiting for a reply.
   * Could the server be experiencing high demand or a temporary outage?  Try again later.
   * Are you unable to browse other sites? Check the computer's network connection.
   * Is your computer or network protected by a firewall or proxy?  Incorrect settings can interfere with Web browsing.
   * Still having trouble? Consult your network administrator or Internet provider for assistance.
AChernow
AChernow's picture
Oh god.. It's been a while
Oh god.. It's been a while since I flashed it. I have no clue. I'm pretty sure it was DLed from here when I did it. If I had to guess I'd say V24. Again, it was a working router *with* that install of dd-wrt. I simply just unplugged the router to move where it was plugged in and when I plugged it back in, it was no longer working.
-Adam
rakha
rakha's picture
Have you rebooted the router
Have you rebooted the router before this? If not, I think the image was improper. Now while rebooting its not getting up.
Or did you change any configuration settings? If the settings of network parameters are changed, it may create problem.
You may try factory reset.
AChernow
AChernow's picture
I'm pretty sure it's been
I'm pretty sure it's been rebooted prior to this. Haven't changed any config settings other than the normal change the SSID, set WPA key, etc.
Is factory reset the same as hitting the button or is there documentation somewhere for that? If you don't have a link I can google for it.
-Adam
rakha
rakha's picture
press reset button for 5 sec.
press reset button for 5 sec. then router will reboot automatically.
jules
jules's picture
Pressing the reset for five
Pressing the reset for five seconds won't do a factory reset. If you unplug it, then hold in the reset button, plug it in, and keep holding the button in for ten seconds or so, that should do the trick.
If I remember correctly, on mine I think it will do a factory reset if I hold the button in for around 45 seconds, but the method above is faster.
George
George's picture
Did you ever find a solution
Did you ever find a solution to this? I am having the exact same problem. Unplugged my router and plugged it back in 30 mins later and now it wont start. Cant tftp it or anything.
George
AChernow
AChernow's picture
I kind of put the thing on
I kind of put the thing on the back burner. I bought a WRT-54GL so it's not a priority to get the Netgear working.
scooter312
scooter312's picture
i am having the same problem.
i am having the same problem. with my router i unplugged it to move it and now not even the power light comes on. i tried the factory reset and still nothing. can use the help feel restricted laptops don't belong tethered to an Ethernet cable
George
George's picture
I have ordered a usb-serial
I have ordered a usb-serial cable to see if I have any luck with that.
If your not even the getting power light, then it sounds like your router is dead.
AChernow
AChernow's picture
Finally got around to getting
Finally got around to getting this going again... Nothing suggested helped. Might have to look into getting a cable for it and doing a reload on it.
prakashsawarkar
prakashsawarkar's picture
i want change my TTL 64 to
i want change my TTL 64 to 128 how to change in tomato firmware 54 GL ?
prakashsawarkar
i want change my TTL 64 to TTL 128 in tomato firmware in 54 GL
keambi
keambi's picture
I used the 'DD-WRT BETA svn
I used the 'DD-WRT BETA svn 14584 with Samba3 for WNR3500L' image and all was working fine. I unplugged my router to move it to a different location under desk, and not it won't respond. I get steady power light, wireless light is off, and if i ping it through cat 5 cable, it will blink but not respond. tried 30-30-30 reset and setting static ip to 192.168.1.10/ 24 and still no luck . just ordered usb - serial to see if i can recover.
Should switch to tomato or get image off or dd-wrt for my wnr3500l?
