I have a WGR614L wireless router and I used tomato 1.25 firmware.But
my wireless host machine can't associated with WGR614L router in WPA or WPA2 security mode.If any one have any idea, regarding this issue then please put some light's on that issue.
wireless host couldn't conected to WGR614L router
Tue, 07/21/2009 - 10:42am
#1
have you tried to use WPA or WPA2 with default netgear firmware .... It seems to be a f/w specific issue ....
Also these security mechanisms are very common and hence are expected to work properly ... so before getting to any conclusion plz check that all the parameters concerned with WPA or WPA2 have been set properly ...
