Victek's Tomato Mod
5 posts / 0 new
RH90
Victek's Tomato Mod
Can anyone confirm if Victek's Tomato Mod (link here) works with this router? I'm currently on Tomato 1.25 but want to switch over to his Tomato mod because of the IP/MAC BW Limiter specifically.
achilles
Does this support broadcom
Does this support broadcom architecture ..... I could not get much from the link (perhaps it z in spanish)......
If it supports the hardware/architecture of ur router then u shud be able to use it ....
RH90
Tathagata Das: I'm using a
Tathagata Das: I'm using a Netgear WGR614L router.
achilles: I always thought if the standard Tomato could run on my router then the mod's could also but I don't want to brick my router. I know that Linksys WRT54Gv8 and WRT54GSv7 uses the same CPU that my router uses which is the Broadcom BCM5354.
achilles
Yep u r right in being
Yep u r right in being prudent ..... Usually standard 3rd party firmwares like Tomato, DD-WRT, OpenWRT etc specify the hardwares that they support ..... so the best bet would be to see what are the hardwares that it supports ...
As far as WGR614L is concerned ,even if it is not supported , u can apply patches and get a f/w that runs on WGR614L but for that u need to have the source code ....
Victek
achilles, your router is not
achilles, your router is not supported by original Tomato and variation, don't upgrade.
