I have bricked my router and now I am recovering it using JTAG, I have uploaded (flashed) the CFE.bin into the router successfully, I powered off the router and then I powered it on but the power LED is not blinking ,which is an indication of failsafe mode.
When I read back the Flashed data from the router , i.e. CFE.bin from the same adress, I got garbage information.
Anyone have idea about it?
Regards
Some possible explanations:
A flash memory block must be erased before it can be reprogrammed.
There's a problem with your JTAG, either the hardware connection, or software.
