So when can we buy a 3500L on Newegg or Amazon?
How long might we have to wait for a Dual Band version of the WNR3500L?
-TAC
I guess I should say simultaneous dual band. My understanding is that the 3500L is dual band (single radio?) but you take a speed hit on the N band when also using G. With a true dual band (two radios) router this isn't the case.
-TAC
The WNR3500L should be available late this month or early November. As far as a simultaneous dual band option, I am not sure - that is for NETGEAR to answer!
Can a 3500 be used with the same DD-WRT binaries? What are differences between a 3500 and 3500L?
