I want to buy the WNR3500L but i need to mount it to a wall.
I couldn't find anything about this on the website.
Can anyone tell me, if this is possible and if the WNR3500L has these mounting holes on the back.
Thanks in advance.
Matthias
Thanks in advance.
Matthias
I think if you wanted to mount it on the wall, you would probably have to construct a shelf or bracket of sorts. Either side of the router case is a glossy panel which doesn't have mounting holes, and even it they did, it probably wouldn't be sturdy.
Again, mounting it flat to the wall with some brackets would probably be pretty simple.
You can see some more pics in the review:
http://www.myopenrouter.com/article/12912/Review-and-Installation-of-NET...
