Hello
I installed openwrt on my WGR614L v8, get well
GUI
The wifi works well
DHCP works well
Test ping 192.168.1.1 Ok
Do not work
No WAN
No SSH
No Telnet
My lights are green and orange
I can load the firmware from fedora 11 or Vista pro
Could you tell me walked the tack, its very important
Thank you for your help
On my router I had to change the WAN interface in /etc/config/network from eth0.0 to eth0. But you might need a serial cable to make that change.
