Enabling SSH on wnr3500l with openwrt
3 posts / 0 new
bier
Hi
I started to play around with a wnr3500l. Installing the (old...) openwrt firmware was easy. First I tried to get ssh access. Failed. Any Hints?
Thanks in advance.
achilles
It seems that the image u r
It seems that the image u r using does not have the ssh support enabled in it...
U can flash an image where ssh is enabled and then it will work ..
bier
Thanks for your help. I hope
Thanks for your help. I hope there will be a new version of openwrt for wnr3500l soon...
