Hello, i have got a big problem! Today i updated my 3500nl to ddwrt 13972 beta chk after that i updated to svn13401. When i was configuring my router my pc got an bluescreen. I started it again and tried to connect to my router but i get no connect to it !
I hope you can help me to get it run again.
If you was configuring your router and not updating it try to reset it. BUT if I where you i would NOT use 13401 because thatÂ’s rather old. Use 13972. I has used 13832 for a month and its "rock solid" so far.
i pushed reset button for 30 seconds then i shut it off and on again but it doesnt work.
I just see that i have a connection to my other pc in the network but not to the router. Maybe the router IP changed?? I am still using 192.168.1.1 ! Does the DDWRT firmware give the router an other ip?
I just got an connection to my router after shut it down non stop while pressing restore button.
dont ask me how i got it to run again
Great....so now all you have to do is upgrade to 13972 :)
