- R8000P would be grate to see. 1 year 20 hours ago
- Have a R8000 but ordered a 1 year 20 hours ago
@uscallesen
Thanks for the info.
Where did you find it? I could not locate any release info/changelog.
BTW: which build are you using?
ND/NDUSB?
-Ext/-Lite/-Std/-vpn?
The info is (well hidden) on the Tomato homepage http://www.polarcloud.com/tomato
Scroll down to the Beta section.
I haven't received my unit yet - only prepping for the installation so far :)
@uscallesen
Ah, I see. Problem is, I am not sure that the one you're referring to hase been ported to the WNR3500L. These have been (the MIPSR2 variants):
http://sourceforge.net/projects/tomatousb/files/
I got my unit yesterday - and flashed to the recommended DD-WRT (based on the dd-wrt router database) - first the "mini" and then the "Standard" firmware.
I'm also experiencing the WAN IP drops like Csimbi - I've got some debugs running on the CMTS - but it definately looks like a faulty DHCP client in dd-wrt and Tomato.
Other than that I pretty disappointed by the throughput on dd-wrt - with the Netgear firmware I could recv/send with 290/128 Mbps - with dd-wrt it is down to 124/96 Mbps without any features besides the SPI firewall enabled.
Did you test the throughput with Tomato?
Have you also WAN dropouts with Tomato?
I haven't moved to Tomato yet - If there indeed is an issue with dhcp on both dd-wrt and Tomato I'd like to get some debugs before moving on to Tomato.
How stable is the latest Tomato release ?
I think the lastest beta7 is rock stable here - no problems at all. I do have connection dropouts (modem goes shortly offline), but thats another story...;)
Flashed with tomato-1.27-ND-9044MIPSR2-beta07-Std.bin - and everything went smooth. I noticed that Tomato has some logging options for the DHCP client and even an option to "Reduce packet size" for DHCP WAN requests - Csimbi you might wonna look into this.
http://www.dd-wrt.com/phpBB2/viewtopic.php?p=302143&sid=43fe0152f073a481...
why is it neccessary (?) to flash first the mini version of DD-WRT when one wants to use Tomato?
Why does the Tomato author not fix this?
Well it's not really an issue - AFAIK the problem is actually with the Netgear firmware that needs to be wiped in a specific way during the first flash - I'd prefer ONE well tested firmware for this purpose over 5 different firmwares maitained by different people.
Thanks for the link. However, the issue does not occur for me on DD-WRT (there is almost nothing to configure on WAN, I guess it's all automatic). WAN drops happened only when I used Tomato; did not try the beta7 yet though.
You will find that firmwares come in different formats (containers): .chk, .bin, .trx.
The Neatgear firmware comes in .chk format and it can flash only .chk firmwares.
DD-WRT comes in both .chk and .bin formats; you just download the one that you are able to flash.
Tomato comes in .trx format, so the Netgear firmware cannot use that for update and therefore, you need some other firmware - such as DD-WRT - to flash it. So, first you flash the DD-WRT .chk and using that you are able to flash the Tomato .trx
As for the question of why not fixing this. Well, I guess he does not care. The best would be if he did not need to care; if there was a converter that is.
If you are referring to 1.25, my advise is stay far away from that rubbish unless you want a defunct router.
What is the difference between the big and small firmware?
WNR3500L. See the first reply of this thread.
@sjau
Nobody can answer you that on this forum. The best you can get is a link to some feature tables/checklists. See this thread for DD-WRT:
http://www.myopenrouter.com/forum/thread/17842/Differences-between-mini-...
@sjau
deltoid posted two links here, one describing the difference between the versions and the other about the Tomato release for WNR3500L.
http://www.myopenrouter.com/article/17506/Installing-Tomato-Early-Firmwa...
3500L running stable since Tomato beta 3 here.
I have a 50Mbit cable connection and have had some lengthy downloads and I never noticed any Wan disconnects.
The only thing I'm slightly disappointed by (not Tomato related I think but the 3500L) is that the range is not as good as my 6 years old Belkin Pre-N router. I got a better connection upstairs (2 floors up through concrete) with the Belkin but usually I'm working about 5 meters from the 3500L and I'm getting full speed (with whatever firmware I'm using) so I'm happy. I've must have tried about a thousand different combination but never got the range as good as the old Belkin (so if any of you have any tips)
I agree the range is not near as good as my older WRT54G.
A external antennae mod might help.
I've also upgraded from the old champ wrt54gl. I agree, about the lower range. But my Iphone can still mangage to get 17 Mbit troughput...
A good solution to this, is a 5 Ghz access point like this:
http://www.netgear.com/Products/APsWirelessControllers/AccessPoints/WNHD...
This setup really rocks for me...:)
Another good solution, could be to set your old WRT54GL up as access point only, and manage the G networks devices. Then set your WNR3500l to N only
Btw, the 3500 should be standing up, not laying flat, for the best wireless signal.
I Just upgraded to tomato Beta7, and well, now I have a truly open router, just not the good kind.
I keep getting asked for the DD-WRT password like Plex mentioned on page 1, but unlike him, I have been unable to get it to go away via reset. I've done 30-30-30, and even 90-90-90 because I became desperate.
I have tried any and every possible login/password combination with no luck. Tried telnetting in, again, login/pass issues.
Already have somebody in the neighborhood on the connection as I can see his Windows share, so I'm shutting this down, as it has essentially become bricked until I can figure out the password it is looking for.
Any ideas/help would be greatly appreciated.
Did you try "root" and password "admin"?
I believe that's what DD-WRT sets it to.
I had the very same problem. I wrote it down; there is a link from the very first post in this thread to the solution that worked for me.
Hi
Has anyone tried to optimize the wireless settings, for better wireless range - if that is possible?
There is a lot of wireless options in Tomato, including transmit power - but it doesn't seems to have any effect :(
The old WRT54GL was _much_ better - maybe because of the external antennas.
I had very good signal all over the house, before upgrading to the Netgear...
It seems to be overkill, to have 3 unit's connected, just to fill out one optimal routers place - WNR3500L+WRT54GL+WNHDE111...
Hi Plex - you did a site survey ?
http://www.dslreports.com/faq/14250
I'm getting excellent coverage with mine.
Yes I have done that, and I'm using a free channel.
With the WRT54GL, I have 90-100% signal strengt all over my house - much better than the WRN3500L.
Well it's only a problem with my 802.11g devices, as I use the 5 Ghz band for my N devices... So maybe I just need to live without tv in my beedroom (Iphone streaming live tv)
New firmware out for those who willing to risk a beta release (beta10). Get it here:
Changelog (note that not all of these apply):
Got Beta 10 this AM and so far so good. Except for the led light deal.
http://www.myopenrouter.com/forum/thread/18354/Orange-power-led-in-tomat...
I will get this router in a few days. Iam abit confused about upgrading this router.
I first need to install DD-WRT firmware right? http://www.myopenrouter.com/download/18819/DD-WRT-for-WNR3500L-v24-svn14...
This one should be ok?
Then i should install this one: tomato-K26-1.27.9045MIPSR2-beta10.01-Std.trx
Correct?
I need to rename *.trx to *.bin?
Do you have any other tip (special rebooting etc.) or this is it??
Doesn't matter since you will be flashing with Tomato immediately afterward. I would just do the Mini and then go straight to Tomato.
