Anyone interested in running OpenWRT-based FON firmware?
12 posts / 0 new
Peter Redmer
Peter Redmer's picture
I'm sure most of you have heard of FON, referred to as "the largest Wi-Fi community in the world" by their official site.
It's an awesome idea; that you share a little of your Internet with others for, in turn, the ability to use any other FON based hotspot.
https://www.fon.com/en/info/whatsFon
This firmware is commonly being used on other Linux routers.  I'm curious, is anyone here looking to run FON firmware on their NETGEAR open source router?  Anybody working on porting it over?
We'd love to hear about it, as we may just have some exclusive opportunities for programmers out there to get involved...
skynetbbs
skynetbbs's picture
it would be best to port Fon
it would be best to port Fon-NG which uses the latest Luci Openwrt and adds a nice looking Plugin system.... call it an "openwrt App Store" :-)
svn co https://svn.fonosfera.org/fon-ng
The netgear doesn't have a usb port I guess?
the FON-NG also runs perfectly on it's Fonera+ counterpart (1 wan, 1 lan, no usb)
but it hasn't yet been tested on a broadcom chipset like the Netgear
AustinTX
AustinTX's picture
Hells, Yeah. If someone makes
Hells, Yeah. If someone makes a fully-functional Fon firmware build that runs on many different routers, then maybe we can get Fon to go back to being a wifi company instead of a merchandiser.
elfonblog dot fondoo dot com
skynetbbs
skynetbbs's picture
Hi, hence FON is based on Openwrt, you can compile it for thesame platforms as the original Openwrt firmware allows. Eg if you compare the "make menuconfig" on a openwrt and a fon source check out ... you will see it's thesame... it only has 5 extra "fon" packages listed...and has a "fonera2" platform... while the fonera/fonera+ can be used with the "atheros"platform selection.
I'm not sure if this Netgear needs to tweak some stuff as well... the "image builder" process sure seems different?
tenkooo
tenkooo's picture
First of all, hello to
First of all, hello to everybody in the myopenrouter community.
I know that this is a relatively old post, but i would like to see the fon firmware ported to the WNR3500L.
skynetbbs
skynetbbs's picture
I'm also interested in seeing
I'm also interested in seeing fon capable firmware running on more hardware
one can get access to the svn.fonosfera.org and get "netgear" destination added to it?
fantoma
fantoma's picture
I would like to have fon
I would like to have fon firmware on the WNR3500L. thanks.
JBF
JBF's picture
+1 for the 3500L
+1 for the 3500L
Peter Redmer
@Roberto - this has been a
@Roberto - this has been a common request on the forums, and sadly nobody that I know of has built this firmware for the WNR3500L... yet. I am by no means a Linux or open source router "expert" myself - although I know enough to get my hands dirty, I couldn't port the fimware on my own by any means!
skynetbbs
skynetbbs's picture
Can only be ported by someone
Can only be ported by someone of Netgear...
As only these people have been porting eg Openwrt or DD-Wrt or Tomato... and not the developers of Dd-wrt/tomato/...
eg there are netgear specific "non opensource" stuff that they can't compile
the howto build of fon-ng is here : http://trac.fonosfera.org/fon-ng/wiki/build
but "make menuconfig" will only yield to destinations ... it's upto the netgear people to add a "netgear" destination with it's propertiery hardware (network/wifi)
Kong
Kong's picture
@skynetbbs,
@skynetbbs,
you are completely wrong here, netgear asus and others use an sdk from broadcom.
This sdk contains a proprietary module + sources for a wrapper module that can be build for the specific kernel. Exactly the same sdk is used by dd-wrt tomato etc.
I haven't looked at the fon sources, but I doubt that they have the need to change code inside the wireless driver.
skynetbbs
skynetbbs's picture
please do take a look and
please do take a look and combine the 2...
imho you will only have to find out the links to the "broadcom" network names...
instead of atheros (ath0/1) and Ralink (ra0/1) they will become something else (broadcom) specific?
