How could I enable bitttorrent support on my WNR3500L with dd-wrt installed?
Thanx
Enable UPNP (make sure its enabled in your client), or do Port forwarding to a specific port for your Torrent client.
Hope this helps. :-)
Hi, Thanx for your reply.
But I meant how can I enable the router built in support for bittorrent client?
UPNP when turned on, detects what port your client is using and port forwards it automatically without you having to mess with settings in the router. By Default, DD-WRT with the right ports forwarded handles and supports torrent clients of all sorts just fine.
Ah my bad bud. Actually haven't looked into that feature yet, I have an AMD Tricore dedicated to that work. Ill keep my eyes open for you guys though.
Thanx Dandan, that's exactly what i meant
