Total noob guide - to torrent client on the Netgear ?
16 posts / 0 new
Hiawatha
Hiawatha's picture
Sorry, but I have read quite alot of posts already and cant seem to find a clear link to or explanation of the usage of a bittorrent client on the wnr3500.
In combination with an attached storage device.. Can someone help me out and either give me a link to clear info or send me a mail with info ?
Thanks in advance
Hiawatha
Hiawatha's picture
:) I am waiting for my
:) I am waiting for my netgear to arrive. I want to use it to share large video files with some friends overseas that are also video enthousiasts.
So the usage would be to have the torrent client running on the router itself so my video editing system can stay powered off (power savings). I have heared that is possible with some Asus firmwares.
Thanks in advance for Tips or info
Hiawatha
Hiawatha's picture
Additionally I found a press
Additionally I found a press release which tells me that their is a good chance Netgear would have or, at least, supports the usage of bittorrent client on the router.
http://www.netgear.com/About/PressReleases/en-US/2007/20070107.aspx
Hiawatha
Hiawatha's picture
Hmm would this be something
Hmm would this be something that could fullfill my wishies ?
http://www.nslu2-linux.org/wiki/Optware/CTorrent
In combination with dd-wrt ?
ctorrent ?
Phew... seems like a whole new world I need to get familiar with, anyone can help me put the steps in order ?
Hiawatha
Hiawatha's picture
Here an updated version:
http://www.nslu2-linux.org/wiki/Optware/EnhancedCTorrent
Anyone that has been able to get this running in combination with CTorrent Control Server on their wnr3500L ?
Kong
Kong's picture
Since I'm missing a few apps
Since I'm missing a few apps too. I currently plan to setup my own ipkg repository. I have installed a few apps with ipkg from the default locations provided by dd-wrt firmware, but most of them don't work without modifying startup scripts, some apps are outdated etc., others don't work at all due to differences in uClibc etc.
My idea is to preconfigure all apps to run inside /jffs dir, this way it should be absolutely easy for a novice to get an run apps for dd-wrt. I have already setup a machine for building dd-wrt firmware, next step is to compile and package a few apps.
Hiawatha
Hiawatha's picture
That would be great, been
That would be great, been trying to read up on everything and im starting to have a bit of an overview what to do when i finally get my router. But for a novice like me, with no prior experience in linux, it is quite a task.
So any fool proof install guide would be great :) and or precompiled .... stuff would be great :)
Hiawatha
Hiawatha's picture
Anyone else have experience
Anyone else have experience and are interested to have a torent client on their 3500 ?
Kristofer
Kristofer's picture
Yes, I am trying to figure
Yes, I am trying to figure out how to do this as well. I have linux experience but I mainly use ubuntu so I am not really an expert on compiling stuff.
I was hoping I can do this on Tomato firmware.. Any hints on where to look?
Kristofer
Kong
Kong's picture
I have completed a set of
I have completed a set of packages among them a torrent client, I have not yet tested the torrent client, but most of the other packages I provide have been tested under dd-wrt with removable media mounted on /jffs.
I just have to write some detailed instructions on how to install,run and configure these apps.
Tadej
Tadej's picture
thanks!!
thanks!!
Hiawatha
Hiawatha's picture
Nice cant wait kong :) would
Nice cant wait kong :) would be my main reason for using a custom firmware, besides all the other improvements.
Kong
Kong's picture
http://www.myopenrouter.com
http://www.myopenrouter.com/forum/thread/19370/Samba3-dd-wrt-optware-pac...
I haven't tested the torrent client, but feel free to test it. If you follow the guides on the linked site you will be able to install ctorrent. Just make sure you installed the package profile first, which will preload some libs that are usually needed.
3ugen
3ugen's picture
did someone test the torrent client? I want to be sure that it is possible to run torrent on the netgear before I purchase it.
thx.
3ugen
Kong
Kong's picture
I did a quick test by
I did a quick test by downloading a suse image which worked just fine.
3ugen
3ugen's picture
Thx for the information!
