Issues related to configuration is generally fixed by obtaining IP address by typing 'ncp.cpl' on 'Run' , It's common for netgear and other LTE routers, however one can Fix NetGear Router Configuration Issue.
What firmware are you using? If outdated you may need to upgrade and then try to save.
It's the latest version, yes.
When I get a chance I will try from another computer - maybe that will do. But still odd if I can't so it from this one.
Paul
Well, I connected to the router with from my MAC and this time I was able to save the config file. Go figure. Maybe it doesn't like Windows7
Hm. Even odd'er - file appeared on the laptop when I restarted it.
