Continuing with my questions. I am working on getting chan_sccp to work. However for my entire setup to work, I would like a tftp server to work too. However I am not sure if I need ip_conntrack_tftp module for the current kernel.
If not, then can anyone let me know how to setup iptables to have tftp server working.
Regards
Uday
Which version of DD-Wrt are you using? Have you able to install tftpd on you board or it is installed. If tftpd is installed in your board, then what outputs are showing when you are running tftpd.
I am using dd-wrt.v24-14311_NEWD-2_K2.6_big.bin which is a 2.6 kernel.
I have installed tftpd on the board and it works within the LAN. I want to reach the server from WAN interface. I did not yet test it with IPTABLES disabled on the WAN side.
