dd-wrt on wnr3500l: /jffs/etc//ipkg.conf: no such file
31 posts / 0 new
el_ninoz
el_ninoz's picture
Hi.
I`m trying to install som Optware packages on my "DD-WRT v24-sp2 (08/10/10) stdkong"-flash. I`m very new at this, but i think I`ve done everything right so far. Done the 30-30-30 reset, done "Netgear WNR3500L Firmware: Special File for initial flashing", and finally the flashed the DD-WRT v24-sp2 (08/10/10) stdkong.
I have followed this guide, but now I`m stuck att this problem:
root@DD-WRT:/etc# root@DD-WRT:~# cd /jffs/etc/
-sh: root@DD-WRT:~#: not found
root@DD-WRT:/etc# -sh: cd: can't cd to /jffs/etc/
> root@DD-WRT:/jffs# cd /etc/
> root@DD-WRT:/etc# wget http://www.desipro.de/pkg.conf
> Connecting to www.desipro.de (82.165.77.220:80)
> root@DD-WRT:/etc# export IPKG_CONF_DIR=/jffs/etc/
> root@DD-WRT:/etc# ipkg update
> /bin/ipkg: line 1166: can't open /jffs/etc//ipkg.conf: no such file
-sh: -sh:: not found
Can someone try to tell me what the problem is? :)
Kong
Kong's picture
HI el_ninoz,
HI el_ninoz,
before "cd /jffs/etc" execute :
mkdir /jffs/etc
el_ninoz
el_ninoz's picture
Hi, tnx for the advice. But
Hi, tnx for the advice. But now it seems like another problem has showed up:
root@DD-WRT:/jffs/etc# ipkg update
Downloading http://www.desipro.de/packages/Packages ...
ipkg_download: ERROR: Failed to retrieve http://www.desipro.de/packages/Packages, returning
ipkg_update: Error downloading http://www.desipro.de/packages/Packages to /jffs/usr/lib/ipkg/lists/desipro
Kong
Kong's picture
Okay, I assume you missed one
Okay, I assume you missed one step in the guide, did you really reboot the rooter 2 times after you setup JFFS2?
The first boot after enabling JFFS2 is to setup the jffs file structure, the second boot will then create the appropriate dirs like /jffs/usr/lib/ipkg
el_ninoz
el_ninoz's picture
I`ve started once again, and
I`ve started once again, and this time I rebooted to times, and waited several minutes (aprox. 5 minutes) each time, like the guide says.
now I dont have the problem with the directories, but I`m still stuck at ipkg update:
root@DD-WRT:/jffs/etc# wget http://www.desipro.de/ipkg.conf
root@DD-WRT:/jffs/etc# export IPKG_CONF_DIR=/jffs/etc/
Kong
Kong's picture
Strange error, it says it
Strange error, it says it cannot retrieve the file, can you show me the output of:
ls -la /jffs/usr/lib/ipkg/lists/
and output of:
mount
does it work if you download the file to the temp dir:
cd /tmp
wget http://www.desipro.de/packages/Packages
now there should be a file called Packages in /tmp
el_ninoz
el_ninoz's picture
Hi.
Hi.
Here is the outpoot of ls -la /jffs/usr/lib/ipkg/lists:
root@DD-WRT:/jffs/etc# ls -la /jffs/usr/lib/ipkg/lists/
drwxr-xr-x    2 root     root         4096 Sep  3 21:36 .
drwxr-xr-x    3 root     root         4096 Sep  3 21:36 ..
root@DD-WRT:/jffs/etc# mount
rootfs on / type rootfs (rw)
/dev/root on / type squashfs (ro)
none on /dev type devfs (rw)
proc on /proc type proc (rw)
ramfs on /tmp type ramfs (rw)
sysfs on /sys type sysfs (rw)
devpts on /dev/pts type devpts (rw)
devpts on /proc/bus/usb type usbfs (rw)
/dev/mtdblock/4 on /jffs type jffs2 (rw)
/dev/discs/disc0/part5 on /jffs type ext3 (rw,data=ordered)
When I did the same thing with the tmp folder, I got the same problem. (Asuming that I did it right) :)
Kong
Kong's picture
If download to tmp does not
If download to tmp does not work you have a network problem. First thing to try would be lowering the MTU value:
Setup->Basic Setup->Optional Settings
Instead of default 1492 set it to 1412
el_ninoz
el_ninoz's picture
I think I misunderstood you
I think I misunderstood you on a earlier post, instead of wget http://www.desipro.de/packages/Packages, I took wget http://www.desipro.de/ipkg.conf to the /tmp folder. And that was the reason I didnt see the Packages in the /tmp folder.
So I did everything once again, and then I could see Packages in the /tmp folder. So I can download it :)
But what do I next? :)
Thanks for all the help so far, I`m very new at this, so I`m very grateful for the help :)
Kong
Kong's picture
If downloading to tmp works,
If downloading to tmp works, then you can just move the file to the dest dir by hand:
mv /tmp/Packages /jffs/usr/lib/ipkg/lists/desipro
After that you can try installing packages.
JHSPerc
JHSPerc's picture
I am having problems with
I am having problems with ipkg on my wndr3700 working.
I try to do ipkg update and I get this:
root@Kuhn:/jffs# ipkg update
mkdir: cannot create directory '//usr/local/lib/': Read-only file system
any clue how I can get it to use /opt or /jffs instead?
JHSPerc
JHSPerc's picture
root@Kuhn:/jffs# ipkg -d root
root@Kuhn:/jffs# ipkg -d root -force-depends install aiccu_20070115-4_atheros.ipk
ERROR: File not found: //usr/local/lib/ipkg/lists/whiterussian
You probably want to run `ipkg update'
ERROR: File not found: //usr/local/lib/ipkg/lists/non-free
ERROR: File not found: //usr/local/lib/ipkg/lists/backports
/bin/ipkg: line 1184: sort: not found
Unpacking aiccu...Done.
Configuring aiccu...Done.
I am trying to install aiccu and get it working...
Kong
Kong's picture
You don't need to use the
You don't need to use the argument "-d root"
JHSPerc
JHSPerc's picture
Even if I remove the -d root,
Even if I remove the -d root, I still get a host of error messages.
Thanks for the reply :-)
Kong
Kong's picture
Just use the option:
-o /jffs
/jffs should already be the default.
JHSPerc
JHSPerc's picture
How do I get ipkg to update
How do I get ipkg to update with this error:
Kong
Kong's picture
Note the double slash in this
Note the double slash in this path, it seems like somehow IPKG_OFFLINE_ROOT is overwritten, because that's the way the path is created:
IPKG_OFFLINE_ROOT=/jffs
IPKG_DIR_PREFIX=usr/lib/ipkg
IPKG_LISTS_DIR=$IPKG_OFFLINE_ROOT/$IPKG_DIR_PREFIX/lists
Therefore your IPKG_OFFLINE_ROOT must be set to only / this could be the case if you use some customized ipkg.conf with the option:
offline_root /
JHSPerc
JHSPerc's picture
How do I set it to use /jffs
How do I set it to use /jffs and can I do that?
I greatly appreciate the assistance :-)
Kong
Kong's picture
What the out put of:
echo $IPKG_CONF_DIR
and
cat
/etc/ipkg.conf
and
fgrep IPKG_OFFLINE_ROOT /bin/ipkg
Normally you should not need to set any directory, there must be some problem with your ipkg.conf or with your ipkg installation.
JHSPerc
JHSPerc's picture
root@Kuhn:~# echo $IPKG_CONF
root@Kuhn:~# echo $IPKG_CONF_DIR
That one is empty
root@Kuhn:~# cat /etc/ipkg.conf
src whiterussian http://downloads.openwrt.org/whiterussian/packages
src non-free http://downloads.openwrt.org/whiterussian/packages/non-free
src backports http://downloads.openwrt.org/backports/rc5
dest root /jffs
dest smbfs /tmp/smbshare
dest ram /tmp
and
root@Kuhn:~# fgrep IPKG_OFFLINE_ROOT /bin/ipkg
s/^/`echo $IPKG_OFFLINE_ROOT | ipkg_protect_slashes`/
if [ -z "$IPKG_OFFLINE_ROOT" ]; then
IPKG_OFFLINE_ROOT="`ipkg_option offline_root`"
# Export IPKG_OFFLINE_ROOT for use by update-alternatives
export IPKG_OFFLINE_ROOT
if [ -d "$IPKG_OFFLINE_ROOT$DEST_NAME" ]; then
IPKG_ROOT="$IPKG_OFFLINE_ROOT$DEST_NAME";
IPKG_PENDING_DIR=$IPKG_OFFLINE_ROOT/$IPKG_DIR_PREFIX/pending
if [ -n "$IPKG_OFFLINE_ROOT" ]; then
local sed_safe_offline_root="`echo ${IPKG_OFFLINE_ROOT} | ipkg_protect_slashes`"
[ -n "$IPKG_OFFLINE_ROOT" ] && return 0
IPKG_OFFLINE_ROOT="$2"
Kong
Kong's picture
What FW are you using, that
What FW are you using, that ipkg differs from the one that is shipped with dd-wrt?
Try the following:
export IPKG_OFFLINE_ROOT=/jffs
after that run:
ipkg update
JHSPerc
JHSPerc's picture
Downloading http://downloads
Downloading http://downloads.openwrt.org/whiterussian/packages/Packages ...
wget: unrecognized option `--passive-ftp'
Doesn't do anything due to this....
Kong
Kong's picture
This is another problem that
This is another problem that comes from an ipkg that does not work together with the tools that are included in this particular firmware.
DD-WRTs ipkg does not use the option --passive-ftp. You should either report this problem to the creator of your special firmware or use some known to work firmware.
JHSPerc
JHSPerc's picture
I will report the issue with
I will report the issue with the DD-WRT package for my router.
How do I go about fixing this issue?
Kong
Kong's picture
You need to use a working
You need to use a working ipkg for example:
http://svn.dd-wrt.com:8000/dd-wrt/browser/opt/bin
copy it to your usb drive and then call it:
/jffs/ipkg update
etc.
JHSPerc
JHSPerc's picture
awesome thanks!
awesome thanks!
So every ipkg command I want to execute I will have to use the /jffs/ipkg and what I want to do, correct?
Robin
Robin's picture
Sorry to hijack this thread
Sorry to hijack this thread but I have the same problem as the original poster, but the solution (reboot twice) doesn't seem to work for me.
When I try to activate JSSF2 on my formatted 40GB ext3 hard drive, only the folders tmp and lost+found are created. I then push again the Reboot router button on the Administration page in the latest Kong mod of DD-WRT, nothing changes, so I can't do cd /jffs/etc
The output is:
I have tried all kinds of things: Apply settings before rebooting, with another USB stick, cold boot, etc.
The settings in Services->USB are as described in http://tips.desipro.de/2010/04/25/dd-wrt-optware-packages/
Any help would be greatly appreciated,
Robin
szgabor
szgabor's picture
I had the same problem....
Reading this thread I got the idea that I can fix this ...I have the shell script version ... copied it to /jffs
Than just looking into the fricken script made the following changes
IPKG_DIR_PREFIX=/jffs/local/lib/ipkg
# IPKG_DIR_PREFIX=/usr/local/lib/ipkg
and delete the --passive-ftp after wget here so it looks like this
http://* | ftp://*)
if ! wget $proxyoption $proxyuser $proxypassword -P $IPKG_TMP $src; then
echo "ipkg_download: ERROR: Failed to retrieve $src, returning $err"
return 1
fi
Then make sure $IPKG_OFFLINE_ROOT is empty ...
The drawback is that you need to run /jffs/ipkg ... but at least it works.
remember to make it executable !!!
Hope this helps someone I wasted quite some hours on this...
Do not understand why my dd-wrt image has this wrong (I am using:
http://www.dd-wrt.com/routerdb/de/download/D-Link/DIR-825/B1/dir825-firm...
Robin
Robin's picture
Thanks for your reply, I'm
Thanks for your reply, I'm looking forward to trying this Saturday, I'll let you know if this worked for me too.
joel
joel's picture
I got the custom dd-wrt
I got the custom dd-wrt package for my Netgear WNDR3700 "DD-WRT v24-sp2 (03/17/11) std (SVN revision 16454)"
I'm stuck at a similar place -- step 1 was:
ipkg gave me a "cannot create directory" error due to RO file system:
Exporting - IPKG_OFFLINE_ROOT=/jffs - helped but then I run into a syntax error on wget. (see below and my issue/question at the end)
root@gw:/opt# export IPKG_OFFLINE_ROOT=/jffs
root@gw:/opt# ipkg update
BusyBox v1.13.4 (2011-03-17 14:04:05 CET) multi-call binary
Usage: wget [-csq] [-O file] [-Y on/off] [-P DIR] [-U agent] url
Retrieve files via HTTP or FTP
Options: (snip.....)
ipkg_download: ERROR: Failed to retrieve http://downloads.openwrt.org/whiterussian/packages/Packages, returning
ipkg_update: Error downloading http://downloads.openwrt.org/whiterussian/packages/Packages to /jffs//usr/local/lib/ipkg/lists/whiterussian
(repeats for another repository)
So... I need a "working ipkg" which I'll look for since the above link is failing.
joel
joel's picture
As mentioned earlier in this
As mentioned earlier in this post - I had to copy /bin/ipkg to a folder in /jffs (I used /jffs/bin, then edit it and remove the passive option, and change the root location)
then I had to create a whole raft of subfolders under the /jff/tmp structure manually.. not sure why.. but I had to create and mark them all writable so that /jffs/bin/ipkg would run and download the updates.
Now it's complaining that "sort" is missing, and I can't install it because it's a pre-req for the ipkg script to run.
why was I doing this again? Oh yes. I need a print driver.
Joel
