Hello folks!
Just one fast quick question, I'm going to use pfSenses built-in DHCP to hand out leases to my clients, and I'm going to put the LAN side in one of the routers LAN ports.
Therefore I'm asking this, I need to disable the built-in DHCP server on the router but will I be able to hand out IP's to my Wi-Fi clients?
//Pontus
I think you can attribute static IP yes.
Disable the LAN side dhcp server. If you say firmware version that you are using, then I can say you where you can dissable it.
Ok, better late then never! :)
Got it to work now, but how the h*ck can I now login to the router and make some configs to it?
//Kirill
When you give static IP without DHCP via router, I think you must configure your computer to use a static IP too. If not, it will search for a DHCP server and won't find it....
Depending on which OS you are using procedure is different...
