I just received and hooked up my new 3500L and the reception is only MILDLY better at best over my old linksys wireless G router. I was under the impression that the range was supposed to be SO MUCH BETTER!! Is this router still any good or should I have bought the new linksys e3000 or Netgear wndr3700?
- Working the EXACT same 11 months 4 days ago
Are you using N clients?
That just may be the problem. I guess I just assumed it would be a drastic improvement on all bands. So I guess that the other two modems I listed would have the same results as well?
Yes you need N clients to take advantage of an extended range.
Thanks for your help. Looks like I will just keep this one then:)
The WNR3500 also offers 1 GB wired speeds and USB support.
But if you don't need wireless N, 1GB wired and USB then you might as well stay with the Linksys.
Same here. I had a WRT54GL running tomato, which allowed me to bump the radio signal up a notch. There are many APs around me (I live in an apt) all at channel 6 or 11, so I'm on channel 1 all by myself. I used to get great signal in my living room at 54Mbps, now it's down to 11Mbps with this new router... I'll probably disable the wifi on the Netgear router since I don't have any N clients, and daisy chain my old WRT54GL for my wireless needs.
