Router WNR3500L with Netgear Firmware V1.0.2.50_31.1.25
OS Win XP Home SP3 with Firefox 3.6.10
Modem Option GlobeSurfer II broadband ethernet to router
I am trying to access via the internet my USB external HDD that is connected to my WNR3500L. My internet connection has a dynamic IP address so I have registered with dyndns.com with a host name under dyndns.org
I have access to my USB HDD from other computers on my network.
In my router setup if have-
Enabled Dynamic DNS Sevice
Provider = hostname.dyndns.org
User Name = username
Password = password
The Dynamic DNS status shows my correct current IP address.
USB Storage (Advanced Settings) has
Enabled = HTTP (via internet)
Link = http://hostname.dyndns.org/shares
Port = 80
When I go to http://hostname.dyndns.org/shares I get a 404 Not Found error. What else do I need to do to access my USB HDD via the internet?
is it possible for you to use a different port other than 80
try another port number, see if that works, or try 8080
