I really like Tomato and it's interface & features is MUCH better than Netgear's. Is there a version of Tomato for a Simultaneous Dual Band N router? I don't care if it's Atheros or Broadcom based. The only 5Ghz Tomato router is a Linksys saucer-based router, which I don't like.
I need it and recomend it's purchase for use in DOCSIS 3, VDSL2 & FIOS installations, which the WNR3500L has serious issues trying to maintain speed when serveral VOD streams are needed. It can barely handle 2 HD Homerun streams and stuttering happens imediately when someone else tries to access the MediaSmart Server.
Hello, there is not any simultaneous dual band N units with tomato support besides the saucer linksys that you don't like, tomato won't and probably never will support Atheros, so for now, your limited on choice and i don't even really know of any other broadcom based unit that is same specs as the wrt610n v2/e3000
