How can I upgrade or reflash my dlink dir825 boot loader?
2 posts / 0 new
kevinx17910
Long story short, I messed up the backuploader/boot loader on my dlink dir825.
The only firmware it will run is openwrt. How can I reflash the boot loader??
Is it possible?
Thx in advance
buddee
You'll most likely need a
You'll most likely need a jtag connection to do that, if the unit's bootloader is fubar, a serial connection will do no good, you'll need jtag, and i do not know if that unit even supports jtag.
