Possible to determine link speed?
6 posts / 0 new
Mainer82
Is it possible via the console/gui to determine the link speed/duplex?
Mainer82
Anyone?
Anyone?
Mainer82
Anyone?
Anyone?
Brandon C
I am not sure what you are
I am not sure what you are asking or what firmware you are running.
Using the Tomato firmware I can see the connections and their link speed.
Since you posted this in the DD-WRT forum are you running it and what version are you using?
Mainer82
I am using build 14826 on the WNR3500L. I want to know if while within the console if it's possible to determine the link speed and duplex of the connected devices.
Mainer82
I know that the default
I know that the default Netgear firmware can do this. Just curious.
