wrn3500l dd upgrade help
3 posts / 0 new
vaporman_ri
Im trying to install dd-wrt with the kong mod onto my wrn3500l. Problem is all the ones i get for the 3500l are in .bins. I cant find a link to the .chk version to first put on it before i can upgrade to the mega. I thought i could just load the .bin from the stock firmware but it needs to be a .chk. Any help would be great, i really want to get this thing up and running with dd. Thanks guys
chris
Vaporsmoke_isgoood
I found the link for the .chk
I found the link for the .chk and have it running nice on the kong build. BUt now no wifi it says that the radio is on but it is not showing up and the wifi led is off. Should a do a reset?
vaporman_ri
Thanks alot got it up running
Thanks alot got it up running very nice with the kong ver. Only problem is no wifi led yet it says the radio is on and it is not broadcasting the ssid.
