I want to Build a Atom Bassed Router
4 posts / 0 new
Possum
Hi
I have 3 power hungry computers that are mostly on. One computer is ALWAYS on. My Netgear router is always on as well.
To reduce my power consumption I would like to build a small low wattage computer that is a router, ADSL modem, WiFi router  and hardwired router.
Other tasks for this comuter will be Torrent Server (legal tutorials) file server and web server (just for me on the road)
Things I need to know..
Router Software
Router Car
All advice welcome
If you have any pointesr and advice to help me start this project I would be very greatful.
Thank You..
Kong
You could actually do most of
You could actually do most of this with a standard wireless router e.g. WNR3500L or the more powerful WNDR3700. The only feature that is not available is the included ADSL modem, but the rest is already possible.
If you would base your router upon a Atom CPU you will end up with a power consuming system, since you need to get a wireless client card, adsl modem card etc. this sums up not to think about the price.
The WNR3500L only consumes 4W. It is rather slow as a fileserver using samba you can expect around 5MB/s . The WNDR3700 reaches around 12MB/s.
I once thought about building an embedded router myself, but I decided to rather use a opensource router and customize the firmware to my needs:-)
Possum
Yes you are right about using
Yes you are right about using the Atom processor. The Netgear WNDR3700 looks to be  a fantastic router. I truely think I would have got one if it had an ADSL modem.
This is really a hobby project for me so I am happy to get a more powerful processor. I will try for a small case but I will need to have room for a
  • router card
  • WiFi card
  • ADSL card
I will continue to investigate my software and hardware options. Any advice on what software and cards will be appreciated.
Thank you...
DJ_SpaRky
The Netgear DGND3700 is the
The Netgear DGND3700 is the WNDR3700 with a ADSL modem built in.
http://www.netgear.com/home/products/wirelessrouters/high-performance/DG...
Sound like exactly what you are looking for. Too bad I can't seem to find them available online, except directly from Netgear. You might want to look at the (lower model) DGND3500, There are a couple of stores out there that have them for ~$130.
