I run a WinXP box in my basement that acts as a file server and media server. I also run uTorrent on the box. How can I setup the QOS for this box so that uTorrent gets low priority but everything else (file shares and media shares) get high or highest priority?
Do I have to just make 2 entries for that IP and specify the uTorrent port on one of them and set that one to lowest?
That should work fine. All of my QoS entries are by specified ports; I usually don't specify IP addresses, but that might work better in your case if you're trying to limit traffic on a specific machine in your network.
