Possible to load balance using two WAN connections and a WNR3500L?
2 posts / 0 new
atek3
atek3's picture
I have cable, and the speeds I get are fantastic downstream, but my upstream is capped at 768 Kbps, which is garbage. On the other hand, I get about 1.5 Mbps upstream via. wifi tethering through my Verizon EV-DO rev. A connection.  What I'd like to do is load-balance between the two connections to get ~2 Mbps upstream.  I'm certain it can be done, but don't know if it can just be done with my WNR (possibly with different firmware) or I'd need a proper server running pfsense.  I should mention that currently half the computers on my LAN connect via gigabit ethernet, and the other half via 802.11g.
Ideas?
I really don't want to have to wait until FiOS to get decent speeds.
atek3
Joey
Joey's picture
This something that is
This something that is missing from most firmware.
Some people have it work using a round robin load balancing scheme, but not a real balancing scheme.
Pfsense does do what you require, look into that, that can't run on this router though.
There is a Tomato MLPPP version that bonds two connections that runs on WRT54G router.
