Netgear WNR3500L.
ISP settings work fine on default Netgear firmware.
When I set up connection on DD-WRT (I tryed 14250, 14896 and 15943 versions) all things going right, but when I set gateway 172.25.4.1 it resets to 172.25.4.224 after button "Apply" , so I cant connect to internet. Every time I set 172.25.4.1 it resets to 172.25.4.224 again and again. And one more thing, where I must sing up DNS? On WAN connection (there's nowhere to set)? or LAN connection (it's not WAN...)?
So my 2 questions:
1) How to set PPTP gateway (172.25.4.1)?
2) How set ISP's DNS?
As far I remember (used dd-wrt long time ago) when setting PPTP in WAN side,I've never been able to set Gateway manually. I just set Gateway (PPTP server) IP address and Gateway was filled in automatically. DNS servers should be automatically set par flush process of the PPTP server.
Ok, maybe it set 172.25.4.224 automatically, but this is wrong gateway. In result PPTP can't setup.
Sorry then can't help you more as I use TomatoUSB/Toastman (no problem with PPTP here).
thx anyway :). offtop/ For me tomato also good, but there's no guest wlan./
Friends! Any Ideas??
up
how can I solve this problem. Who can debug this??
