I was enabling Jumbo Frames and got this message:
The field "clkfreq" is invalid. Please report this problem.
and it won't save the setting for me. Does this mean my router doesn't support that feature? or another problem?
ok got it... on that same screen, the field for cpu frequency said undefined. I picked a value, rebooted the router, and we're good.
So now the question is.. what cpu frequency is safe to use on the 3500? I don't want to overclock it much or at all. It does not let me put it back to undefined and there is no 133 option which was what it ran at before making the change.
The correct default value is 453 MHz for 3500L. Higher frequencies are quite instable.
I have been running at 480 Mhz w/o any issues but I also keep the router as cool as possible. I wouldn't try to go any higher than that tho.
