is there some docs on entering a new classification (QoS) ?
I want to show bittorrent traffic stand out on the graph separately - I know the port number(s)? It says VOIP/Game right now. I'd like to enter a new class.
The screen is a little confusing and I'd like to look at docs before messing around with that. thanks.
the latest version allows you to change the class names, but not add new ones. I think it's good enough for my purposes though, so thanks!!! to the developers of Tomato and also thanks to Toastman.
Not sure what you mean, bit torrent by default will end up in the "P2P/Bulk" class (if you use my class names). If you want some P2P that is currently not being classified correctly to be placed into that class, make another rule with your known port numbers by all means. Now that you have the ability to change the class names, you can move things around pretty much as you wish.
