hi guys.
I just upgraded my DD-WRT firmware to Kong's mod firmware build 16625M. I tried to use my external HD through USB port of my Asus RT-N16. I followed instructions here on how to do this but I still can't get windows 7 to see my HD. Here are the setting:
USB tab:
Core USB support --> Enable
USB Printer Support -->Disable
USB Storage Support --> Enable
Automatic Drive Mount --> Enable
Disk Mount Point --> /mnt
Disk Info:
--- /dev/discs/disc0/disc
Block device, size 465.8 GiB (500107862016 bytes)
DOS/MBR partition map
Partition 1: 465.8 GiB (500105217024 bytes, 976768002 sectors from 63)
Type 0x07 (HPFS/NTFS)
NTFS file system
Volume size 465.8 GiB (500105216512 bytes, 976768001 sectors)
Status: Mounted on /mnt
NAS tab: File Sharing
Samaba --> Enable
Workgroup --> WORKGROUP
Path to Files --> /mnt
Puble Share --> Enable
Readonly --> Enable
Use Custom Config --> Disable
I even disable the homegroup sharing in windows 7 and still can't see my HD. Is there another step to see the HD or is it automatically appear in Network? Thanks for any help
Have you tried to access it through Windows Explorer by entering:
\\RoutersIP\Public
Thanks for the reply. I got it figured out. \\routername\public
