my usb drive is set up in 3 partitions. 1.2TB in ext3 for the NAS, 32MB for a swap, and 200GB in NTFS (for use in Windows).
When i plug in to the router, it automounts the ext3 partition and everything works fine there. I cant seem to manually mount the NTFS drive though.
the command "mount /dev/scsi/host1/bus0/target0/lun0/part3 /tmp/transfer" does nothing. Ive tried mounting in other folders as well and still nothing.
the router sees and recognizes all partitions.
root@DD-WRT:/lib/modules/2.6.24.111/kernel/fs# cat /tmp/disktype.dump
--- /dev/discs/disc0/disc
Block device, size 1.365 TiB (1500301910016 bytes)
DOS/MBR partition map
Partition 1: 1.174 TiB (1290548543488 bytes, 2520602624 sectors from 2048)
Type 0x83 (Linux)
Ext3 file system
Volume name "Main"
UUID E3CA7235-7465-46BC-9C4C-043747FCC56B (DCE, v4)
Volume size 1.174 TiB (1290548543488 bytes, 315075328 blocks of 4 KiB)
Partition 2: 32 MiB (33554432 bytes, 65536 sectors from 2930204672)
Type 0x82 (Linux swap / Solaris)
Linux swap, version 2, subversion 1, 4 KiB pages, little-endian
Swap size 31.99 MiB (33546240 bytes, 8190 pages of 4 KiB)
Partition 3: 195.3 GiB (209703513600 bytes, 409577175 sectors from 2520614565)
Type 0x07 (HPFS/NTFS)
NTFS file system
Volume size 195.3 GiB (209703513088 bytes, 409577174 sectors)
any idea how to mount this NTFS partition?
Since automount currently only mounts the first partition you have to do two things, load fuse module:
insmod /lib/modules/2.6.24.111/kernel/fs/fuse/fuse.ko
mount using command:
ntfs-3g /device /mountpoint
e.g.:
ntfs-3g /dev/discs/disc0/part3 /mnt
You can add those commands for example under:
Administration->Commands-> Save startup
this way the get executed each time the router reboots
is the fuse module new? i dont have it in build 15758M
root@DD-WRT:/lib/modules/2.6.24.111/kernel/fs# ls -l
drwxr-xr-x 2 root root 24 Nov 19 23:45 cifs
drwxr-xr-x 2 root root 28 Nov 19 23:45 exportfs
drwxr-xr-x 2 root root 24 Nov 19 23:45 ext2
drwxr-xr-x 2 root root 24 Nov 19 23:45 ext3
drwxr-xr-x 2 root root 23 Nov 19 23:45 fat
drwxr-xr-x 2 root root 23 Nov 19 23:45 jbd
drwxr-xr-x 2 root root 25 Nov 19 23:45 jffs2
drwxr-xr-x 2 root root 25 Nov 19 23:45 lockd
-rw-r--r-- 1 root root 8880 Nov 19 23:45 mbcache.ko
drwxr-xr-x 2 root root 25 Nov 19 23:45 msdos
drwxr-xr-x 2 root root 23 Nov 19 23:45 nfs
drwxr-xr-x 2 root root 24 Nov 19 23:45 nfsd
drwxr-xr-x 2 root root 82 Nov 19 23:45 nls
drwxr-xr-x 2 root root 24 Nov 19 23:45 vfat
nevermind, just using the ntfs-3g command worked. thanks again!
Ok my older build had it compiled into kernel, now it is compiled as a module so it can be loaded only when needed.
Konggggg !! You saved my life !!
I've gone around many forums to find out the right solution for a whole day.
AAAAAArgggggg, now my combo works perfectly !!
1. Buffalo WZR-HP-AG300H running DD-WRT v24SP2-MULTI (06/03/12) std - build 19154
2. Ext HDD Buffalo 500GB with 3 NTFS partitions
3. Raspberry Pi, access resources in ext HDD via the router
These commands works for me:
root@DD-WRT:~# insmod /lib/modules/2.6.24.111/kernel/fs/fuse/fuse.ko
root@DD-WRT:~# ntfs-3g /dev/sda1 /mnt
root@DD-WRT:~# ntfs-3g /dev/sda3 /mnt
root@DD-WRT:~# ntfs-3g /dev/sda5 /opt
