I've been using Tomato for years on a WRT54GL. I've just ordered a brand new WNR3500L to replace it as the interface speeds are starting to show their age.
I'd also like the functionality to create a VPN at home, I'm under the impression that some of the builds include this?
Which build should I go for? Does this one include OpenVPN or similar?
http://www.myopenrouter.com/download/26575/Toastman-s-Tomato-Firmware-fo...
Or is it this one...
http://www.myopenrouter.com/download/26165/Tomato-Firmware-v1.28.2453-MI...
(I don't really need transmission etc.)
Also would restoring my existing router settings (standard 1.28 release of Tomato) onto the new device work? I don't really want to reconfigure everything...
There's a bigger choice here:
http://www.4shared.com/dir/v1BuINP3/Toastman_Builds.html
You ought to reconfigure, because strange things can happen if you do not. However, this makes it very easy:
Thank you.
Router arrived, flashed with DD-WRT and then Tomato. Reconfigured everything and it seems to be running nicely. I've noticed some fancy new features already, nice work!
There's now a version for K24 MIPSR1 routers, such as the WRT54GL.
Look for v 7621.1
Have you succeeded to create VPN. Can you please provide me the steps to create
it?
Thanks in advance.
Best place to look for info on that is Linksysinfo.org, there's a forum thread devoted to it.
Thank you for the information.
