The wireless on my router has stopped working.
I can sometimes establish a connection, but once I do I cannot communicate with anything on the network, if I can even get a connection in the first place. This same phenomenon happens with all my wireless devices. The wired connections work fine.
I'm using DD-WRT. I seem to have tried everything. From doing a 30/30/30 reset to upgrading my router firmware to messing with wireless configurations.
I need wireless but it seems the only option is to buy a new router. I want to get a good DD-WRT router, but I don't want to buy another WNR3500L again if it is just going to break like the first one.
Please help.
Can please tell which DD-WRT firmware are you using?
Are you having the same problem with stock firmware too?
