Here is a question I have had for awhile and cannot find the answer to. Under the "Wireless Access Points And Clients" area, I never get any information on the Uptime, TX Rate and RX Rate. It always shows N/A. My router is a Wnr3500L. Is there anyway to get this to show the proper information?
thx.
I guess you are not using Stock firmware,but any other third party firmware.
Then it should be noted that third party firmwares uses opensource WebUI, which provides many options. Only if your firmware is equipped with those functionalities then only you will be able to use them. I guess those features are not provided by your wl driver. In that respect I fully agree with kt_haddock.
