Any WNR3500L firmware source code to access WiFi packet's Qos & TX/RX IP address?
3 posts / 0 new
Linda75
   Do you know if there is any version WNR3500L firmware source code available which allows you to access WiFi packet's Qos type & WiFi packet's source/destination IP or MAC address?
Thanks in advance!
Subhra
As per my knowledge,wl driver
As per my knowledge,wl driver's source code for WNR3500L is not available(object code is provided instead).
Linda75
Thank you, Subhra.
Thank you, Subhra.
I want to add DSCP Qos tag for one IP address so that WiFi packets sent to that destination will have higher priority. Should I use "filter" or "mangle" in IPtable??
