access restriction doesn't work with VPN client Tomato USB VPN client
15 posts / 0 new
wyse
wyse's picture
I am using Netgear 3500L Tomato Firmware v1.28.9054 MIPSR2-beta K26 USB vpn3.6
When i use access restriction and also web usage logging, all is ok.
But, when i start also vpn client (am using an external vpn provider) , access restriction doesn't work anymore and web usage doesn't log anymore ?
If i stop vpn client, all is ok again about logging and acces restriction.
What does this mean ?? Is the VPN masking info to these services ?
I am using TUN on UDP, automatic firewall, create NAT on tunnel is cheked, Redirect Internet traffic also.
Where is the problem ? :(
An idea ?
Thanks for any help.
wyse
wyse's picture
Ok, it is confirmed, these
Ok, it is confirmed, these functions can't operate simultaneously.
If you start vpn client, acces restriction and web monitoring will stop.
Mikey0124
Mikey0124's picture
Hello, I know this is an
Hello, I know this is an older thread but does anyone have a solution to this problem with the access restriction not working or web monitor when the VPN is enabled?
wyse
wyse's picture
no haven't got any solution.
It seems that as the flow is in the tunnel it can't be filtered or analyzed any more.
Mikey0124
Mikey0124's picture
Okay thanks for the reply,
Okay thanks for the reply, I have been searching for hours on google trying to find a solution and nothing....
wyse
wyse's picture
should the flow enters tunnel
should the flow enters tunnel after treatment analyzes and restrictions.
A normal software layer router, then a layer after VPN connection.
I do not know if this is possible.
Mikey0124
Mikey0124's picture
I have got a user at another
I have got a user at another forum that says he has OpenVPN setup on his router and he/she is not having this problem. Might be our settings I was told.....I am going to play around a bit more tonight and will update here if I get any more info
wyse
wyse's picture
could be great :)
could be great :)
Mikey0124
Mikey0124's picture
Well I have changed just
Well I have changed just about every setting and and cannot get the web monitor or access restrictions to work when the vpn is running.
Where/who did you hear that the that this wouldn't work? Do you still use your vpn?
Mikey0124
Mikey0124's picture
Anyone have an update with
Anyone have an update with this problem that can help?
Mikey0124
Mikey0124's picture
okay guys I got it working
okay guys I got it working FINALLY. Here is what I had to do basically
Basically I had to use 2 routers for this to work. My first router: Has an ethernet cable from the WAN port to my modem. Then I run another cable from the LAN to the WAN of my second router.
So my first router is setup to get the main internet connection. I also have this router setup fully to connect with the VPN.
My second router now has an internet connection with vpn through my first router and now my access restrictions and web monitor is working.....
wyse
wyse's picture
Yes, ok, great, but a little
Yes, ok, great, but a little bit expensive.
Why not :)
Mikey0124
Mikey0124's picture
Not really expensive....  you
Not really expensive....  you can get another router an older router that works with custom firmware for cheap .....around 30 bucks....
I am so glad I got this working.......I have been looking on the internet for months.    Went to a few different forums and no one had any answers.    I figured this one out myself.    Now I just have to try and get ipv6 working through it and I am all set
kk74
kk74's picture
Does anyone know of another
Does anyone know of another solution to this other than using a second router...
kk74
kk74's picture
