Hello all,
I'm facing a weird issue here. Once I connect my WAN port to the line coming from the ISP my DNSmasq can't reply correctly to DHCP requests. Only clients who can get an address are our Win XP laptops but my Ubuntu, our both Androids and Logitech Squeezebox just can't get an address from the router. When I disconnect the WAN line and reboot the router then all clients are happy with DHCP.
I'm running DD-WRT v24-sp2 (07/20/11) stdkong (SVN revision 17356M) on a WNR3500v2/U/L.
My dnsmasq.conf looks like this:
interface=br0
resolv-file=/tmp/resolv.dnsmasq
all-servers
domain=b37
dhcp-leasefile=/tmp/dnsmasq.leases
dhcp-lease-max=19
dhcp-option=lan,3,192.168.1.1
dhcp-authoritative
stop-dns-rebind
expand-hosts
Try to reconfigure the router to use of the address space 192.168.0.x, so the router would be 192.168.0.1, instead of now 192.168.1.1
Does this change anything?
try and uncheck DHCP-Authoritative after the pppoe connection is established clients should get ip
Thanks guys,
I got an interim solution by reverting to a really old config which doesn't seem to have this issue. It does have the same address space (192.168.1.0) and DHCP-Authoritative is enabled so the issue is caused by something else.
Otherwise the config is really different from the new (not working) one, though. Does anyone happen to know an easy way to find the differences between two configs?
can you post your config
Do you mean the .bin file I get when I take a config backup?
just wanted to know how you configured dhcp and dns using dnsmaq.
