Which is the best way to orient the 3800 for max wifi signal? Are the antenna omni-directional?
Setup of the 3800 was a breeze!
The antennas are omnidirectional so as long as you don't lay it down on its side and make sure it is centrally located as possible and not obstructed you shouldn't have a problem.
