New Toastman Builds
142 posts / 0 new
Toastman
The readme file has this
Toastman
There are some new builds
Raptor
Hi Toastman!
Hi Toastman!
jorel009
hi toastman, great mods; i
thanks.
Starick
Can Toastman do a MLPPP
Starick
Mercury Joe
nm..
nm..
Toastman
raptor - thanks for that
Toastman
I haven't any idea about the
Toastman
Answering some mail:
Toastman
Allows real time and 24 hour graphic monitoring per client.  Per-IP traffic stats and history.
CONTAINING:
  • MiniDLNA 1.0.22: cvs 2011-08-25
  • Miniupnpd ver. 1.6 (20110725)
  • Dnsmasq: 2.58 update
  • Busybox 1.18.5 update
  • radvd: 1.8.1 update
  • ebtables: update to 2.0.10-2 (August 11th, 2011)
  • Samba 3: security updates CVE-2011-2522 & CVE-2011-2694
  • ntfs-3g release 2011.4.12
  • IPV6 improvements
  • BCM SDK: 5.10.142.0: wireless driver
  • BCM SDK: 5.100.138.9: wireless driver in RT-N builds
  • PPP: single line MLPPP support
  • Support for Belkin F7D3301/F7D3302/F7D4301/F7D4302/F5D8235v3 routers.
  • Added support for USB led on E3000, WRT610Nv2, DIR-320, H-618B routers.
  • Various optimizations backports and fixes from upstream 2.6 kernel.
Toastman
The new makefile from Teddy
Good luck!
Tcom
Pardon my ignorance but I've
Toastman
The last "official" tomatoUSB
Aqualung
Dear Toastman, first of all,
Toastman
Okay, then if you have a
Moonshine
Boy or girl, my next shall be
Toastman
Oh, that's an easy one. Take
Moonshine
Just what the doctor ordered,
wbt
Hello Mr. Toastman,
Hello Mr. Toastman,
What am I missing here?
Brandon C
wbt said: What am I missing here?
Did you notice this?
TO TURN IT ON IF YOU NEED IT.
You will need to set up a static IP address on your computer to access the router and  then change that setting if needed.
wbt
@Brandon: WAN has DHCP
Toastman
Toastman-RT-1.28.7488.2
Lothsahn
Toastman:
Toastman:
2) Has anyone used it?
3) Is it reliable?
...and why can't Netgear put way more than 16MB flash in these things? How about 512MB-4 GB? Flash is so cheap... I'd pay an extra few bucks for it and it would let us modders do so much more.
les86
Hi, Please give my advice
dbmet
Which version do we download
d
dbmet
Which Version for a WNR3500l
d
john6699
Can anybody confirm the dlna
Henrlk
Hi, you got me curious, i
Hardware: Netgear WNR3500L
Toastman
