Having never used Tomato myself, I'm hoping you experts can help me understand the lingo.
I was going for this one:
tomato-K26USB-1.28.7476MIPSR2-Toastman-RT-Ext.trx.zip
because it's on your forum and most used, and I don't know any better.
My friend recommened this:
tomato-K26USB-1.28.7486.2MIPSR2-Toastman-RT-VPN+NOCAT.trx
because it's a newer build.
Now I agree that newer build is better, cause it should have less bugs, more features, more security and greater stability. But since I don't know much about router lingo, what it means to me is confusing.
To me:
VPN means: the ability to set up a private network
NOCAT means I cannot use my gigabit LAN ports... which would suck, since that's partially why I bought this router.
So can you guys help me understand the lingo:
What do these terms mean:
MIPSR1
MIPSR2
VPN
NOCAT
RT
VLAN-RT (Virtual LAN-RT?)
RT-MINI
RT-Lite
RT-Ext (Extended? The Ext file is much larger than the Std, which is larger than the Lite)
RT-Std (Standard? what exactly is standard?)
RT-VPN
NoUSB (I'm guessing can't use the usb port on router)
NVRAM (Non Volatile RAM? What does this have to do with the firmware?)
VLAN-RT-N
IPv6
why are some (tomato) files .trx and some .bin?
Also I was told that my WNR3500L router is a MIPSR2 router, is this so?
and here:
http://www.myopenrouter.com/article/13860/WNR3500L-Open-Source-Guide-Res...
a post where the author is written as NETGEAR, says the chipset has a "Dual band radio transceiver". I know for a fact that the WNR3500L can have dual WANs. A main WAN and a Guest WAN (not sure if it supports more, only now learning about it). But on the box and site where I bought it says "IEEE 802.11 b/g/n 2.4 GHz", which means it's single band. Can anyone give some insite on this? Is the dual band radio transceiver simply referring to the dual WAN or can I install firmware in it to make it a true dual band?
I would start here and look at their list on the types.
http://tomatousb.org/doc:build-types
