Hi
Are there any Routers up to the standard ( or close ) of the NETGEAR WNDR3800 that are modems as well?
What is the best Modem Router you know of?
Thank you..
I found these 2, you can do some more research to see if they meet your requirements.
NETGEAR DGND3300 RangeMax Dual Band Wireless-N Router with Built-in DSL Modem
http://www.amazon.com/NETGEAR-DGND3300-RangeMax-Wireless-N-Router/dp/B00...
Motorola SURFboard Gateway SBG6580 DOCSIS 3.0 Wireless Cable Modem
http://www.amazon.com/Motorola-SURFboard-Gateway-SBG6580-Wireless/dp/B00...
